Flip the device to the backside, and locate the metal tab at the center of the back cover.
Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
Lift the battery plate off to either insert or remove 2 AA batteries.
With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
The motherboard should look like this. If it is dirty, gently use a small paintbrush to clean it of dust.
With the pointed end of a spudger (or the small end of a Philips #00 screwdriver), gently unhook the small black tabs by pressing into the interlocking hooks that are sunk into the white wire connector.
Gently pull the wire ribbon from the white connector.
It is easy to pull the ribbon cable off, but reinserting the ribbon cable back into the wire connector is very challenging. Any tips?
crwdns2935229:05crwdne2935229:0
Hello, friend. Name’s Arthur. I have this old Garmin Etrex H GPS device (the yellow one) and it looks very similar to your Etrex Vista H, but it has no stick button. The disassembling method suited just fine here, so I thank you Sir for this tutorial. I was trying to disassembly my Garmin because I am having a problem with its display. There’s a vertical line that its not displaying, so I decided to take a look. However, there was something strange. The display contacts were not locked by a connector, but by something like a durex tape. Seemed very precarious. Have you ever disassembled this yellow Etrex H model? Any ideas on how to solve my problem?
arthurhenriquedefreitasamaral - crwdns2934203:0crwdne2934203:0
I forgot to remove battery for years and the battery chamber got damaged. So chamber was cleaned and repaired but now I cannot on it.
My gps often says low battery when the battery is fine.
It just shuts off after a while of saying ‘low battery’.
How can I fix this?
Perhaps I need to take it apart and clean something to do with the battery connection?
I did once have a small battery leak but it all looked good…. did not see any damage.
We have a Garmin etrex vista h..we are using it..but the battery had been leak for just an hour..we opened it.it was still good..but 2days later we opened it.it still open but the bottons are not working..what will we do?
We have a Garmin etrex vista h..still using it..but we open it the bottons are not working..what will we do?
