This guide will show you how to disassemble the back and side panel of the printer.
Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
Lift up the back cover to remove it.
"quite a bit of force" is almost an understatement, I found 2 clips along the bottom of that rear piece, one at the far left one around the middle (indicated by an arrow on the underside of the machine) - undoing these required much persistence with a screwdriver
Thank you, Perhaps Fuzz. Thank you.
Remove the blue lever from its slot by pushing it back and twisting clockwise.
Close the scanner compartment and cover.
Pry open the side cover with the plastic opening tool.
Flip the printer over so that the bottom of the printer is facing you.
Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
Use the plastic opening tool to loosen the side panel from the bottom of the printer.
Good job!!!!
Where is the rest of disassembly?
