This guide shows how to disassemble a complicated (but cheap) SLR lens, and hopefully reassemble it in working order. Please note that this is a fiddly and complicated procedure; if you value your lens and definitely need it to work, service it. I purchased an "untested" camera from eBay that had obviously been drop tested.
First, remove the two Phillips #000 screws in the barrel of the lens.
Next, remove the four Phillips #000 screws holding the lens mount of the lens on.
Remove the lens mount, and then remove the rubber seal (shown in place around the edge of the lens in this picture).
Note the piece of plastic that just fell out. Not a good sign!
Gently lift and remove the plastic barrel next to the focus switch. My one was already cracked.
Gently manipulate and remove the AF/M focus switch - it is held in by four easily breakable brittle plastic clips.
Watch out for the autofocus mechanism and control wires. They are very delicate.
It's a good idea to switch the lens to manual at this point - adjusting the focus can help when removing the autofocus motor
Remove the top two control wires by releasing the clamps, and then gently easing the wires from the connectors
Do not remove them by pulling the sticking out plastic parts (one is obscured by my finger here) - these will tear off
Gently lever the control board out from under the plastic tabs
Mind the cable underneath the board
Make sure you don't touch the lens element in the center!
Lift up the board, and then gently pull the lower connector out by the solid connector
Then, remove the control board entirely
Next, we will remove the autofocus mechanism.
Remove the two Phillips #000 screws shown.
Be careful with the control cables. They tear easily. The aperture control cable on this lens is damaged already.
Lift off the focusing mechanism.
It's best to have the focusing mechanism in manual (M) - then extending the lens will help you remove the mechanism.
Remove the ringed screw and lift out the metal key guide.
Remove the three Phillips #000 screws holding the rear element and aperture in place.
Gently turn the zoom so it is nearly at 35mm.
This will lift the rear element and aperture unit towards the rear of the lens, and align the three legs with gaps.
Lift the rear element and aperture unit out.
Gently rotate the aperture unit anti-clockwise so that the three ringed legs no longer lock it in place.
On my lens, there was one of the three legs intact, and the aperture unit was hanging off uselessly.
If your aperture unit is like mine, apply superglue around the outer rim, and replace.
Don't get any on the glass!
That's as far as I went - the zoom was no longer jammed, and reassembly was the best option here! Reassembly is the reverse of disassembly.
The aperture unit/rear element is slightly tricky to put back. Make sure you align it correctly (lens nearly at 35 mm, so that the screw holes are high up).
Put the random bits of plastic in your man (or woman) drawer. Who knows when they will come in handy?? But seriously, here's what I found:
That slightly torn aperture cable did not affect operation of the lens. It works perfectly.
Completely reassemble the lens and test on your SLR/D-SLR. Now you can take badly exposed shaky indoor shots like the one shown again!
Don't think you can get away without those tiny screws in the barrel. They hold the contacts in place. I tried and focusing did not work!
Complete disassembly and some super glue fixed my lens, but not everyone will be so lucky.
crwdns2935229:014crwdne2935229:0
crwdns2935103:0crwdne2935103:0
crwdns2947412:07crwdne2947412:0
Very good
Very good
Is there any way to disassemble the lens from the front to clean front elements?
I don't have a manual for this particular lens, but typically it is possible. From what I can see from pictures, there doesn't appear to be any exposed screws to unscrew or any holes on the front ring to be able to use a spanner wrench on. It's hard to tell from pictures, but the model name on the front of the lens seems like it might be a name plate which would be held on with a bit of adhesive. If this is the case, you should be able to peal off the front name plate and there will likely be screws underneath. Taking off those screws would allow you to access the front lens element.
Use caution though: often times there aren't holes the screws are in, but rather slots. This allows the the front lens element to be rotated to different positions. If the lens element isn't put back in the exact rotational position as it was prior to removal, the lens will no longer be properly focused.
Zephosk -
Ι have the same issue
you might see this https://petapixel.com/2013/05/16/a-few-e...
disassemble the lens from the front is a mystery, anyone will help?
