Digital2 Platinum Pad 9 Battery Replacement
  1. Digital2 Platinum Pad 9 Battery Replacement, External Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the plastic opening tool and insert it into the crease between the screen and the plastic casing and press down.
  2. Digital2 Platinum Pad 9 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digital2 Platinum Pad 9 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After inserting the plastic opening tool, run it around the device a few times to loosen the external cover.
  3. Digital2 Platinum Pad 9 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digital2 Platinum Pad 9 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once you've gone around a few times a corner will pop up, insert the opening tool there and repeat step 2 with slightly more pressure. Do this until every section of the backing has popped up.
    • Then just remove the backing.
  4. Digital2 Platinum Pad 9 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery is the bigger square object in the center of the device held down by 3 pieces of yellow tape.
  5. Digital2 Platinum Pad 9 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the tape that is holding down the battery.
  6. Digital2 Platinum Pad 9 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Digital2 Platinum Pad 9 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the battery it will be glued to the device.
    • Be sure to gently work it to loosen and remove so that you do not damage your device.
  7. Digital2 Platinum Pad 9 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
David DeMeritt
crwdns2935283:003/08/16crwdne2935283:0
637 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 5-6, Landers Spring 2016 crwdns2935289:0UMass Dartmouth, Team 5-6, Landers Spring 2016crwdne2935289:0
UMASSD-LANDERS-S16S5G6
crwdns2942667:0crwdne2942667:0 363
