Dexcom G6 Receiver Battery Replacement
  1. Dexcom G6 Receiver Battery Replacement, Display and Front Bezel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 6 Torx T5 screws from the back of the device
  2. Dexcom G6 Receiver Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dexcom G6 Receiver Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift up the screen assembly ribbon cable flap, then remove the ribbon cable.
    • Screen Information: Model AM0310R-04 Lot # NHT18080052
    Thank you! Where can we buy the screen?
    Enrique - crwdns2934203:0crwdne2934203:0
    I didn't get any of the details on the screen when I tore it down, I will try to get the information from the original display when I can.
    Andrew S -
    Have you found any info on getting a replacement Screen? Some company must make theses
    Jim Beamed - crwdns2934203:0crwdne2934203:0
    Yes, this would be great to know. I can't afford to replace this a 4th for my Daughter, but I while heartedly believe in right to repair!!
    Rafael Rasillo -
    I'm not sure if you can find the displays anywhere. The only number (presumably model number) I could find on the screen was AM0310R-04 and the Lot Number NHT18080052.
    Andrew S -
  3. Dexcom G6 Receiver Battery Replacement, Charging Port: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, unplug the Charging Port connector from the motherboard.
  4. Dexcom G6 Receiver Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 silver Torx T5 screws holding the charging port down.
  5. Dexcom G6 Receiver Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the Charging Port Assembly from the motherboard.
  6. Dexcom G6 Receiver Battery Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the silver Torx T5 screw holding the motherboard down.
  7. Dexcom G6 Receiver Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dexcom G6 Receiver Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger, carefully remove the battery connector on the left side of the motherboard.
  8. Dexcom G6 Receiver Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, carefully pry up the motherboard to remove it.
  9. Dexcom G6 Receiver Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dexcom G6 Receiver Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dexcom G6 Receiver Battery Replacement, Battery: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use heat to soften the adhesive holding the battery down.
    • Carefully use one or more opening picks to remove the adhesive holding the battery down, then remove the battery.
Andrew S
crwdns2935283:007/30/21crwdne2935283:0
15 331 crwdns2915208:0crwdne2915208:0
crwdns2947412:010crwdne2947412:0
Where do you get battery? Dexcom won't sell it.
Richy - crwdns2934203:0crwdne2934203:0
I'm not sure you can get this same battery somewhere else (I haven't performed a battery change myself, just took it apart for demonstration). I'll get back to you if I can figure out a way to use another battery.
Andrew S -
@richy14330 The connector type is JST ACHR-03V.
Andrew S - crwdns2934203:0crwdne2934203:0
Still looking ... Where to get a battery for this receiver? What type of battery is it ?
Julian Payne (Xfactor) - crwdns2934203:0crwdne2934203:0
I don't think you can get a replacement battery for this device anywhere. It is a 950 mAh 06220 battery made by Jhih Hong Technology. The model number seems to be BAT000023 and the type is 1ICP4/44/59.
Andrew S -
My receiver doesn’t have screws to even open it up to even find a battery. ??
Peggy86 - crwdns2934203:0crwdne2934203:0
Does yours have the MFG PN # MT24078?
Andrew S -
Where can I get help to replace battery, as I am not computer savvy. I live in Maryland and I need someone to perform this replacement for ne. Pls. Help.
Patricia Norman - crwdns2934203:0crwdne2934203:0
Where can I get help to replace battery, as I am not computer savvy. I live in Maryland and I need someone to perform this.
Andrew S -
crwdns2936753:030crwdne2936753:0 72
crwdns2942667:0crwdne2942667:0 4,243
