Dell XPS 15 9560 Touchpad Replacement
  1. Dell XPS 15 9560 Touchpad Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Touchpad Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  6. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingernails to gently "walk" the battery connector directly out of its socket.
  7. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
  8. Dell XPS 15 9560 Touchpad Replacement, Hard Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove four 4.0 mm screws of the hard drive bracket.
    • Unplug the hard drive cable.
  9. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the hard drive bracket. Then, unplug and remove the hard drive.
  10. Dell XPS 15 9560 Touchpad Replacement, Trackpad: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5 mm mounting screws.
  11. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver to remove the single 5 mm screw securing the silver plate.
  12. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
  13. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the black cord.
    • Unplug the cord with a white plug.
  14. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the white ribbon cables out from their housings. To disconnect, use a spudger or your fingernail to gently lift the looped tab away from the connector. It should pop up easily.
    • Next, use the spudger or your fingernail to push the plastic tab away from the socket. It should move slightly.
    • Now, pull the white ribbon cables out.
  15. Dell XPS 15 9560 Touchpad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the laptop as shown.
    • Separate the touchpad from the keyboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Taylor Hancock
crwdns2935283:001/18/22crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team 2-6, Rauch Spring 2022 crwdns2935289:0Embry-Riddle Aeronautical University, Team 2-6, Rauch Spring 2022crwdne2935289:0
ERAU-RAUCH-S22S2G6
crwdns2942667:0crwdne2942667:0 4,593
