Dell XPS 15 9560 Battery Replacement
  1. Dell XPS 15 9560 Battery  Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before beginning, unplug the charger and any peripheries. If possible, discharge your battery below 25%.
    • Shut the laptop down.
  2. Dell XPS 15 9560 Battery  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  3. Dell XPS 15 9560 Battery  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips screwdriver, remove two 5 mm screws underneath the XPS badge door.
  4. Dell XPS 15 9560 Battery  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wedge the scribe between the backplate and remove the bottom base cover.
  5. Dell XPS 15 9560 Battery  Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
    On the Dell XPS 15 9560 that I just did a battery replacement on the battery was not held in by torx screws. It was the larger 97wh battery and was held in by 6 phillips head screws. I was able to get them out with a PH1 bit.
    Nick Hamblen - crwdns2934203:0crwdne2934203:0
    Seconded. In the photo the author isn't even holding a torx driver.
    Gregory Robben -
    Same, by me it was held by 8 philips screws labeled M2X4.
    Sven Oelker - crwdns2934203:0crwdne2934203:0
    Mine is the smaller battery, held in by four PH0 screws. The two towards the middle of the computer in the photo above are not present.
    Gerald Dennett - crwdns2934203:0crwdne2934203:0
  6. Dell XPS 15 9560 Battery  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the battery cable.
  7. Dell XPS 15 9560 Battery  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:011crwdne2935229:0
Jada Houser
crwdns2935283:009/28/21crwdne2935283:0
848 crwdns2915208:0crwdne2915208:0
Clemson, Team 4-5, Hunter Fall 2021 crwdns2935289:0Clemson, Team 4-5, Hunter Fall 2021crwdne2935289:0
CLEM-HUNTER-F21S4G5
crwdns2935297:019crwdne2935297:0
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 76
crwdns2936753:030crwdne2936753:0 208
crwdns2942667:0crwdne2942667:0 12,070
