Dell XPS 15 9550 RAM Replacement
jbaseballin2
crwdns2944107:0crwdnd2944107:0jbaseballin2crwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Dzi 21, 2022crwdne2944111:0
6 - 7 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2942287:0crwdne2942287:0
The RAM is the part that collects the data for the computer. You will want to replace this because the computer is running slow. Replacing the RAM will allow the laptop to run faster.
crwdns2944105:0crwdne2944105:0
  1. Dell XPS 15 9550 RAM Replacement, Back/Underside Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop upside down.
    • Make sure the laptop is turned off.
    • Use a T5 Torx Screwdriver to remove the ten 3 mm long screws from the perimeter of the back of the laptop.
  2. Dell XPS 15 9550 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9550 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open up the information panel door (on the middle of the back side).
    • While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
    use a J1, fits a lot better. no risk of rounding
    noah.mooresmith - crwdns2934203:0crwdne2934203:0
  3. Dell XPS 15 9550 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9550 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 15 9550 RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the 2 corners of the back panel close to the hinge upwards, to release the whole panel.
    • Do not force the panel off. If it does not come off easily, try to use a plastic spudger where it is stuck.
    Dégouté d'avoir suivi cette étape à la lettre ?
    N'ouvrez SURTOUT PAS le panneau par les deux coins arrières du côté de la charnière !!!
    Et N'utiliser SURTOUT PAS une spatule en plastique pour l'ouvrir si le panneau ne se détache pas facilement !!!
    Le panneau est fait pour s'ouvrir par les coins avant!!! A l'arrière des picots servent justement à l'empêcher de s'ouvrir !!!
    Le résultat si vous utiliser uns spatule à l'arrière… c'est que ces picots cassent… ?
    IL FAUT DONC OUVRIR LE PANNEAU PAR L'AVANT !! Et il est juste posé donc inutile d'utiliser une spatule…
    Voilà voilà je suis dégoûté d'avoir fait cette connerie alors qu'en cliquant sur un autre tuto (lien juste en dessous sur Google) ils le disent…
    J'espère qu'après mon commentaire l'auteur de ce tuto fera la modif…
    Sur ce… merci pour le tuto…
    Tanguy de Guenyveau - crwdns2934203:0crwdne2934203:0
    Bonjour Tanguy ! Désolée de votre mésaventure :( Et merci de ce retour fort précieux à qui voudra effectuer la réparation ! Votre commentaire est visible par tous, donc les utilisateurs seront avertis. iFixit est un wiki ; si vous le souhaitez, vous pouvez également adapter le tutoriel d’origine pour inclure votre retour d’expérience.
    Claire Miesch -
  4. Dell XPS 15 9550 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9550 RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 2 separate RAM sticks.
    • Gently push down on the 2 outside tabs of the RAM stick you want to replace.
    • While still pushing down, gently push the tabs outwards, causing the RAM stick to flip up.
    Removing the RAM to replace the keyboard isn't entirely necessary. It's such an easy step though that protecting your RAM might be worth doing.
    Peter Moeykens - crwdns2934203:0crwdne2934203:0
  5. Dell XPS 15 9550 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9550 RAM Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grasp the RAM stick from the flipped up edge and gently pull out, to release the RAM stick.
crwdns2935229:05crwdne2935229:0
jbaseballin2
crwdns2935283:010/04/18crwdne2935283:0
117 crwdns2915208:0crwdne2915208:0
UW Stout, Team S6-G1, Ogden Fall 2018 crwdns2935289:0UW Stout, Team S6-G1, Ogden Fall 2018crwdne2935289:0
UWSTOUT-OGDEN-F18S6G1
crwdns2935297:023crwdne2935297:0
What type ram do you replace it with? Could you post a link?
twrfan - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 9,034
