Dell XPS 15 9510 Display Assembly Replacement
  1. Dell XPS 15 9510 Display Assembly Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Display Assembly Replacement, Display Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws (eight total) from each display hinge using a Phillips #00 screwdriver.
  5. Dell XPS 15 9510 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove five screws that connect the display using a Phillips #00 screwdriver.
    A step is missing here: remove the two small black screws on each side of the display ribbon cable, as seen on step 2 of the Dell repair steps: https://www.dell.com/support/manuals/en-...
    Justin Decker - crwdns2934203:0crwdne2934203:0
    Also disconnect the two monitor ribbon cables from the board
  6. Dell XPS 15 9510 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the display from the Dell XPS 15 9510.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Austin Sa
crwdns2935283:003/30/22crwdne2935283:0
432 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-3, Mellen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-3, Mellen Spring 2022crwdne2935289:0
UMASSD-MELLEN-S22S1G3
Missing a very important step.
Two small screws above the display cable clamp - Step 5 - need to be removed. If you look at the picture in step 5, the far left red/orange circle actually contains one. You can spot it inside and at the top of the of the circle. You can't separate the display assembly without removing those 2 screws.
Joshua Kleier - crwdns2934203:0crwdne2934203:0
Aren't there any cables that need to be removed?
Ned Eff - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 99
crwdns2942667:0crwdne2942667:0 3,781
