Dell XPS 15 9510 Battery Replacement
  1. Dell XPS 15 9510 Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back panel of the laptop off and set it aside.
    Please do not miss this warning of it being sharp...
    After opening a few laptops for my office, I have generally been fine. But after opening my own XPS... I had sliced my finger badly.
    Alipoodle M - crwdns2934203:0crwdne2934203:0
  4. Dell XPS 15 9510 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9510 Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the small battery pull tab, disconnect the battery connector from the motherboard.
  5. Dell XPS 15 9510 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
  6. Dell XPS 15 9510 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 15 9510 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are many delicate components in the vicinity of the battery, so be extremely careful removing it
    • Remove the old battery from the laptop.
crwdns2935229:08crwdne2935229:0
Joseph Remondi
crwdns2935283:003/30/22crwdne2935283:0
326 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-3, Mellen Spring 2022 crwdns2935289:0UMass Dartmouth, Team 1-3, Mellen Spring 2022crwdne2935289:0
UMASSD-MELLEN-S22S1G3
XPS 15 9510 states the battery (purchased from ifixit) is FAKE and the battery will not charge.
Jacques Aucamp - crwdns2934203:0crwdne2934203:0
can somebody verify this? I want to purchase replacement battery (want it to work.. )
Tommy Pickles -
crwdns2936753:07crwdne2936753:0 111
crwdns2936753:030crwdne2936753:0 351
crwdns2942667:0crwdne2942667:0 7,814
