If your laptop is suffering from a faulty battery, it might be time for a replacement. Make sure the laptop is completely turned off before attempting to replace the battery.
Locate the spring latch on the bottom of the device that will unlatch the battery.
Hold the spring latch in the open position and pull the battery out of its recess.
For optimal performance, after completing this guide, calibrate your newly installed battery.
