Dell XPS 13 9365 2-in-1 Display Assembly Replacement
  1. Dell XPS 13 9365 2-in-1 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Torx T4 screwdriver to remove the eight screws (M2x3) that secure the base cover to the palm-rest assembly.
  2. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingertips to lift the system badge open and reveal the single case screw.
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x4) that secures the base cover to the palm-rest assembly.
  3. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting from the front corner of the computer, pry up the base cover using a spudger and lift the base cover off the palm-rest assembly.
  4. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery cable from the system board.
  5. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x4) that secure the battery to the palm-rest assembly.
  6. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the six screws (M2x3) that secure the battery to the palm-rest assembly.
  7. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery off the palm-rest assembly.
  8. Dell XPS 13 9365 2-in-1 Display Assembly Replacement, Display Assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the screw (M1.6x2.5) that secures the wireless-card bracket to the motherboard.
  9. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the wireless-card bracket off the wireless card.
  10. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of nylon tipped tweezers to gently disconnect the antenna cables from the wireless card.
  11. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the tape that secures the display cable to the M.2 solid-state drive heatsink.
  12. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two screws (M1.6x2.5) that secure the display cable bracket to the motherboard.
    • Lift the display cable bracket off the display cable.
  13. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the pull tab to disconnect the display cable from the motherboard.
  14. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the touch-screen cable from the system board (labeled "TS").
  15. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the camera cable from the system board.
  16. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the palm-rest assembly fully and place the display assembly and palm-rest assembly face down.
    • Make sure that your surface is flat and free of objects when you lay the laptop face down.
    • Use a Phillips #000 screwdriver to remove the six screws (M2.5x3.5) that secure the display hinges to the palm-rest assembly. There are three on each side.
  17. Dell XPS 13 9365 2-in-1 Display Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the display assembly off the palm-rest assembly.
Melissa Schlein
crwdns2935283:003/21/22crwdne2935283:0
731 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 3-4, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 3-4, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S3G4
how to disassembly hinge for replace the video cable?
Logan Solo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 1,214
