Dell XPS 13 9305 Battery Replacement
  1. Dell XPS 13 9305 Battery Replacement, Remove the back screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 9305 Battery Replacement, Remove the back screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.2 mm-long screws.
  2. Dell XPS 13 9305 Battery Replacement, Release the clips: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 9305 Battery Replacement, Release the clips: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At each corner, insert an opening pick between the back cover and the device body.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Dell XPS 13 9305 Battery Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9305 Battery Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9305 Battery Replacement, Remove the back cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The edges of the cover are very sharp. Use caution when handling this panel.
    • Lift the front edge of the cover away from you.
    • Some clips may release during this step. If the cover is stuck, move it side to side to help release additional clips.
    • Remove the back cover from the laptop.
  4. Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9305 Battery Replacement, Disconnect the battery cable: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the battery connector out of its socket using the pointed end of a spudger.
    • Push the small tabs on the side of the connector to avoid damaging the cables.
  5. Dell XPS 13 9305 Battery Replacement, Unfasten the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell XPS 13 9305 Battery Replacement, Unfasten the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five screws securing the battery:
    • Four 2.4 mm-long screws
    • One 4.4 mm-long screw
  6. Dell XPS 13 9305 Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9305 Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell XPS 13 9305 Battery Replacement, Remove the battery: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery straight out of its recess and remove it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
169,240 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,567crwdne2935297:0
This replacement was extremely simple. I have some experience from years ago when I replaced laptop parts during an internship, but was worried things might have gotten a lot more complicated in the 15+ years since. But it was super easy. This guide + the toolkit made it an absolute breeze. I was actually surprised how easy this was. I'm convinced almost anyone can do this. Thanks for the tutorial!
Bono - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 39
crwdns2936753:030crwdne2936753:0 176
crwdns2942667:0crwdne2942667:0 5,024
