This guide will walk through how to replace the display assembly of the Dell Vostro 5510 laptop. The purpose/function of a display is to be able to view information given on a laptop. Symptoms of a display not working is if it displays No Signal or if it doesn't display anything other than a black screen. If the laptop is powered on but the screen displays No Signal, see this link for troubleshooting the problem/issue: Monitor No Signal. Furthermore, if the laptop doesn't display anything other than a black screen even after powering it on, restarting the video drivers, and resetting the RAM, the parts/components of the laptop screen must be broken down and replaced by following the steps below.
Place the laptop so the bottom cover is facing upwards.
Remove the remaining (M2x4mm) screws with the screwdriver.
Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
Pry open the top left corner of the cover with the opening tool.
Pry open the top right corner of the cover with the opening tool.
Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
Lift the cover to remove it from the rest of the laptop.
Remove the six 4 mm hinge screws using the Phillips #0 screwdriver.
Flip up the hinge panel for the left side of the laptop.
Flip up the hinge panel for the right side of the laptop.
Disconnect the display cable with your hands.
Lift up the laptop with your hands to detach it from the display assembly.
