When your computer and monitor both power on, but the monitor shows "No Signal", there are several possible causes relating to the communication between the two. Follow these steps to diagnose the problem and get your monitor working.
First Steps
Make sure both your computer and the monitor are turned on.
Check any monitor cables you have plugged into your computer, e.g, HDMI, DisplayPort VGA, or DVI cables. Unplug and reseat the cables.
Note: Some DisplayPort cables have a button that needs to be pressed in to disconnect properly.
Make sure the monitor's input source is set properly.
Completely unplug the computer, monitor, and any docks or switches between them. Once they're all disconnected, plug them in again.
Mix and match cables, monitors, and sources that are known to work to isolate where the problem is.
Dead/Wrong Cable
Check your monitor cable for any physical damage. If you notice any creases, tears, or unnatural bends, your cable might be preventing a proper connection. This applies to any dongles or adapters connected to your monitor cable.
Check your monitor cable for its version, such as your HDMI 2.0 or DisplayPort 1.2 being used for HDMI 2.1 and DisplayPort 1.4. This is especially relevant for displays with high refresh rates.
To test if your monitor cable is dead or mismatched, use the cable included with the monitor and see if your monitor gets a signal.
Wrong Multi-Monitor PC Settings
If you're using multiple monitors, make sure your computer is set to "Extend" or "Mirror" rather than using a single display.
On Windows, you can right-click on the desktop and select "Display Settings" and on Mac go to "System Preferences" or "System Settings" and select "Display."
Invalid Resolution or Refresh Rate
Make sure your resolution and refresh rate settings are supported by your monitor. If you're playing a full screen game, it may allow you to select an unsupported resolution or refresh rate. Many games can be switched to Windowed mode by typing ALT+ENTER.
Unsupported G-Sync or FreeSync
G-Sync and FreeSync are variable refresh rate (VRR) technologies. If your computer has VRR enabled and your monitor doesn't support it, the monitor might get no signal.
Any devices in the signal path, e.g., docks like Dell WD19TB, that don't support VRR could also cause a no signal.
Damaged or Dirty Ports
Damaged or dirty ports on your monitor could prevent cables from seating properly. Check the ports on both your computer and monitor for any corrosion, dirt, or bent connectors. Follow this guide to cleaning the port(s).
If your port is damaged, replace the port or the monitor entirely.
Faulty Video Card
If your computer has a discrete video card, it may be damaged or improperly connected. Make sure the card is properly seated and connected to power.
Driver Issue
Outdated drivers could prevent your monitor from connecting. Download your drivers (NVIDIA and AMD) and install them.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
250.472 crwdns2915208:0crwdne2915208:0
crwdns2935297:01.201crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:010crwdne2931471:0
crwdns2935297:061.972crwdne2935297:0
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 217
crwdns2942667:0crwdne2942667:0 4,312
