Dell Precision 7510 Memory Module Replacement
  1. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the release latch to unlock the battery cover.
    • Slide and lift the battery cover to remove it from the computer.
  2. Dell Precision 7510 Memory Module Replacement, Removing the Battery Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    This should be called "removing the battery", isn't it?
    ricky-fe - crwdns2934203:0crwdne2934203:0
  3. Dell Precision 7510 Memory Module Replacement, Removing the Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the hard drive to the computer.
    • Lift the hard-drive latch to the unlock position.
    • Slide and lift the hard drive from the computer.
  4. Dell Precision 7510 Memory Module Replacement, Remove the Screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws that secure the hard drive. Lift the hard drive away from the bracket.
    Why is this necessary for replacing the keyboard?
    Nathan Gelderloos - crwdns2934203:0crwdne2934203:0
    I'm gonna go on a limb here and say you can skip this step....
    Jonesy - crwdns2934203:0crwdne2934203:0
  5. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard Cables: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the tape to access the cable.
    • Lift the tab and disconnect the keyboard cables from the system board.
  6. Dell Precision 7510 Memory Module Replacement, Removing the Keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the keyboard trim starting from bottom and work along the top edge and remove it away from the computer.
    • Remove the screws that secure the keyboard to the computer.
    • Lift the front side and slide the keyboard to remove it away from the computer.
  7. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that secures the memory shield to the computer.
    • Lift and remove the memory shield from the computer.
    • Pry the retention clips away from the memory module until it pops up.
    • Lift the memory module and remove it from the computer.
    Between this and the next step, there should be at least one step for removing the bottom body plate.
    Doing so would appear to require removing to screws under the battery cover (removed in step 1) near the left and right corners of the plate (on tabs that extend under the battery cover), and 4 screws on the back of the laptop. I don't know if Dell hid additional screws under the rear rubber feet, like HP likes to do, as I haven't disassembled my 7510 yet.
    Chris Buckley - crwdns2934203:0crwdne2934203:0
    Just remove the two screws near the battery and slide the cover to the back
    J E -
  8. Dell Precision 7510 Memory Module Replacement, Removing the Memory Module: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry the retention clips away from the primary memory until it pops up.
    • Lift the primary memory and remove it from the computer.
Johnathan Hammond
crwdns2935283:002/28/18crwdne2935283:0
45.306 crwdns2915208:0crwdne2915208:0
crwdns2935297:0408crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:043crwdne2931471:0
crwdns2935297:01.991crwdne2935297:0
Thanks Johnathan. Step 4 is unnecessary.
Joseph R. Scandora - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 11,182
