Dell Latitude E7440 Hard Drive Replacement
  1. Dell Latitude E7440 Hard Drive Replacement, Prepare the laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Hard Drive Replacement, Release the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E7440 Hard Drive Replacement, Release the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E7440 Hard Drive Replacement, Release the battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Hard Drive Replacement, Remove the battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E7440 Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
    • Slide the service tray using the middle stand offs to then be able to lift the tray off.
    It is very important to add pictures from the cmos battery instructions on ifixit for this laptop before Step 5, as it gives the very important instruction to SLIDE DOWN the unscrewed cover towards the battery. I nearly damaged it by trying to pop it off before thinking to look at a different set of instructions to make sure I wasn’t going to break the back panel.
    Petie Martin - crwdns2934203:0crwdne2934203:0
    Thank you so much for this comment. I was doing the same thing trying to unsuccessfully pull off the cover but then saw that there was a comment. If somebody who holds themself out to be knowledgeable does not bother to go step by step it can cause a problem. Thanks again.
    Calvin Jordan -
  5. Dell Latitude E7440 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E7440 Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four M2 x 3mm Phillips #0 screws from the hard drive cage.
    • Remove the hard drive cage by lifting it off the laptop.
    • The hard drive cage is not pictured here, but the screws will be in these locations.
  6. Dell Latitude E7440 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E7440 Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the hard drive connector from the top of the drive.
    • iFixit's device came without a hard drive to picture. Your device will have a component connected to the thin, black connector.
    • The hard drive connector can be removed from the laptop body to make replacement easier.
    What is the max thickness for the SSD? Thanks.
    Philip Huffman - crwdns2934203:0crwdne2934203:0
    If you are going to bother to show how to remove the HD you should do it with an HD installed.
    Calvin Jordan - crwdns2934203:0crwdne2934203:0
    Mine has one, but it’s also a poor candidate to show how not having anything but the drive cable.
    Nick -
Akash Kedia
crwdns2935283:001/24/19crwdne2935283:0
1 472 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S2-G5, White Winter 2019 crwdns2935289:0Cal Poly, Team S2-G5, White Winter 2019crwdne2935289:0
CPSU-WHITE-W19S2G5
Hi, my problem is the opposite, I have an hard drive but seems like my HDD connector doesn't plug in the small port. I can send you a pic, I need help
†Winterfall† - crwdns2934203:0crwdne2934203:0
I want to use a Seagate hard disk, but when I start it, it demands me a password. Can you help me in this case please?
Aldoni JB - crwdns2934203:0crwdne2934203:0
It sounds like your BIOS is locked to only work with that hard drive
Magnus Vacuum -
crwdns2936753:030crwdne2936753:0 79
crwdns2942667:0crwdne2942667:0 12,373
