Dell Latitude E6540 Hard Drive Replacement
  1. Dell Latitude E6540 Hard Drive Replacement, Hibernate your laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Hibernate your laptop: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It is possible to plug the laptop in to avoid hibernating the system.
    • Locate the Hibernate option in the Start menu. Let the system fully hibernate (or shut down) before removing the battery.
  2. Dell Latitude E6540 Hard Drive Replacement, Unlock the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Unlock the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop over and unlock the 2 battery tabs. The tabs will remain unlocked until the battery is removed.
  3. Dell Latitude E6540 Hard Drive Replacement, Remove the old battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Remove the old battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Remove the old battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The "extended runtime" battery on this model will stick out a few inches by design. This cannot be avoided.
    • Remove the battery. Pull the battery up from the back.
  4. Dell Latitude E6540 Hard Drive Replacement, Install the new battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Install the new battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Install the new battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step does not apply if this guide is being used as a prerequisite.
    • Align the battery with the tabs on the chassis. Drop the battery in place once lined up. If needed, use light pressure to seat it in the computer.
  5. Dell Latitude E6540 Hard Drive Replacement, Plug your laptop in: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the computer on and plug the charger in.
  6. Dell Latitude E6540 Hard Drive Replacement, Remove the chassis screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Remove the chassis screws: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Remove the chassis screws: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • EET owners: Your kit has this bit. No purchase needed.
    • The screw marked in orange is directly screwed into the chassis. This point WILL break if overtightended.
    • To remove the hard drive from the computer, remove the two screws. Use the Phillips #1 bit.
  7. Dell Latitude E6540 Hard Drive Replacement, Remove the drive clip: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Remove the drive clip: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Remove the drive clip: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • This step is not required if you are moving the drive to an identical Dell computer.
    • To remove the drive clip, remove the Phillips #0 screw holding the hard drive to the clip.
    • Once the screw is removed, remove the drive starting from the side with the screw.
    • Remove the drive from the right side by removing the drive from the alignment pin.
  8. Dell Latitude E6540 Hard Drive Replacement, Remove the rubber bumpers: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Remove the rubber bumpers: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude E6540 Hard Drive Replacement, Remove the rubber bumpers: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The bumpers are held on with double sided tape. This does not have to be replaced.
    • Once the drive is removed from the clip, remove the rubber bumpers. Transfer them to your new drive.
Nick
crwdns2935283:011/10/09crwdne2935283:0
94,716 crwdns2915208:0crwdne2915208:0
crwdns2935297:059crwdne2935297:0
crwdns2942667:0crwdne2942667:0 7,435
