This guide will show you how to safely remove and replace the internal battery of your Dell Latitude 9410 2-in-1 laptop.
Please be careful of the ribbon cable, it is thin and fragile.
Place the laptop upside down on a flat surface.
Use a Phillips #00 screwdriver to loosen the ten captive screws.
Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
Use a Philips #00 screwdriver to remove one 4.5 mm screw.
Grip the battery cable near the plug and pull it straight out, in the direction of the cable.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to gently move the speaker ribbon cable away from the bottom of the battery.
This is a fantastic guide. Thanks for posting it.
Just one question about the speaker ribbon glued to the battery (Step 7). I can't remove the ribbon from my battery. The glue is very strong. I've pulled firmly, and I'm worried about breaking the cable. Any ideas about how to loosen the glue without damaging the computer, perhaps by applying heat or some sort of solvent?
