If your Dell Latitude 9410 2-in-1 laptop ever begins to run out of battery quickly, or shut down on you whenever charging; using this guide will allow you to change that part of your laptop- the battery.
The battery is the main thing that powers your laptop, without it your laptop will fail to charge or even start, there are cases where the battery even becomes inflamed and that becomes a hazard.
Before using this guide, plug your charger in a couple of times and let your laptop run and see if it shuts down. As well as attempt different laptop charges to see if it is a issue with your charger or the laptop.
Step 4 Requires you to slowly lift a piece of Ribbon cable, make sure to lift is slowly and carefully as that is an extremely fragile piece that tears easily.
Before beginning this guide, ensure that the laptop is not only powered off but also disconnected from any outside power source.
Place the laptop upside down on a flat surface.
Use a Phillips #00 screwdriver to loosen the ten captive screws.
Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
Use a Philips #00 screwdriver to remove one 4.5 mm screw.
Grip the battery cable near the plug and pull it straight out, in the direction of the cable.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to gently move the speaker ribbon cable away from the bottom of the battery.
This is a fantastic guide. Thanks for posting it.
Just one question about the speaker ribbon glued to the battery (Step 7). I can't remove the ribbon from my battery. The glue is very strong. I've pulled firmly, and I'm worried about breaking the cable. Any ideas about how to loosen the glue without damaging the computer, perhaps by applying heat or some sort of solvent?
Can I replace by 78WH battery instead of 52WH? I've seen online that 78WH battery is larger than 52WH, though I haven't measure the size.
Thank you!
Pahalavitiyala Sunandananda - crwdns2934203:0crwdne2934203:0
