Dell Latitude 5580 Battery Replacement
  1. Dell Latitude 5580 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 5580 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 5580 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient your laptop so that you have access to the bottom cover, with the fan vents facing upwards.
    • Use a Phillips #00 screwdriver to loosen the eight screws securing the bottom cover.
    • They are captive screws and do not fully come out of the holes. Don't force them or you may damage the screws or holes on the bottom case.
    • Insert the end of an iFixit opening tool or opening picks into the seam between the bottom and top case to release the clips holding them together.
    • Slide the opening tool or pick around the edge of the laptop until it is fully separated.
    • Remove the bottom cover.
  2. Dell Latitude 5580 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 5580 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 5580 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single Phillips #00 screw that is holding down the battery.
  3. Dell Latitude 5580 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 5580 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pull tab to gently pull the battery cable out of its socket.
  4. Dell Latitude 5580 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 5580 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the old battery.
    • To install the battery connection cable, push gently into the original connection port to connect the replacement battery to the computer. Tuck in the battery connection cable underneath the plastic frame next to the battery.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
For optimal performance, calibrate your newly installed battery after completing this guide.
Jack G Johnson
crwdns2935283:004/09/25crwdne2935283:0
243 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team 1-5, Karnes Spring 2025 crwdns2935289:0Linn Benton Community College, Team 1-5, Karnes Spring 2025crwdne2935289:0
LBCC-KARNES-S25S1G5
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 294
