Dell Latitude 5411 Webcam Replacement
  1. Dell Latitude 5411 Webcam Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen all eight 2.5 mm captive Phillips #1 screws that secure the lower case.
    • As the screws are captive, they will remain in the case after being loosened.
  2. Dell Latitude 5411 Webcam Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the base cover starting from the left hinge.
    • If it is hard to pull off, make sure that all the screws are loose.
  3. Dell Latitude 5411 Webcam Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 5411 Webcam Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the battery connector pull tab straight up to disconnect the battery.
    • Remove the one 2 mm Phillips #1 screw that secures the battery.
    • Lift the battery straight up and out of the chassis.
  4. Dell Latitude 5411 Webcam Replacement, Laptop Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 5411 Webcam Replacement, Laptop Camera: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one 1 mm Phillips #1 screw that secures the Wi-Fi card.
    • Take note of which color wire went into each spot, then disconnect the antenna cable connectors by lifting them straight up.
  5. Dell Latitude 5411 Webcam Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 2 mm Phillips #1 screws that secure the display cable bracket.
    • Pull straight up on the display connector pull tab to disconnect the cable.
    • Disconnect the touchpad connector by pulling it straight out of its socket.
  6. Dell Latitude 5411 Webcam Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 2.5x5 Phillips #1 screws securing the hinges to the chassis.
  7. Dell Latitude 5411 Webcam Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open up the laptop to 90 degrees.
    • Pull the laptop chassis from the laptop screen and separate them.
  8. Dell Latitude 5411 Webcam Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into seam between the bezel and the back display cover. Slide and pry around the entire perimeter to separate the entire bezel from the back cover.
  9. Dell Latitude 5411 Webcam Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2.5x3 Phillips #1 screws.
  10. Dell Latitude 5411 Webcam Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the display up and out.
  11. Dell Latitude 5411 Webcam Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 5411 Webcam Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the camera cable.
    • Lift the laptop webcam up and out.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Phillip Nguyen
crwdns2935283:009/27/24crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 163
