Use this guide to replace the battery in a Dell Latitude 5411.
            Loosen all eight 2.5 mm captive Phillips #1 screws that secure the lower case.
            Lift the base cover starting from the left hinge.
            Pull the battery connector pull tab straight up to disconnect the battery.
            Remove the one 2 mm Phillips #1 screw that secures the battery.
            Lift the battery straight up and out of the chassis.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Love y'all guys!! Will be ordering the batt ASAP..!
