Dell Latitude 3189 Battery Replacement
  1. Dell Latitude 3189 Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 3189 Battery Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3189 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3189 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 3189 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Latitude 3189 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Latitude 3189 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 3189 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
  6. Dell Latitude 3189 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Latitude 3189 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the battery and lift it up and out of the chassis.
For optimal performance, calibrate your newly installed battery after completing this guide.
Bryan Pratt
crwdns2935283:002/14/24crwdne2935283:0
667 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 2-3, Sneed Spring 2024 crwdns2935289:0University of Memphis, Team 2-3, Sneed Spring 2024crwdne2935289:0
UM-SNEED-S24S2G3
crwdns2942667:0crwdne2942667:0 298
