Dell Inspiron 7348 2-in-1 RAM Replacement
  1. Dell Inspiron 7348 2-in-1 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7348 2-in-1 RAM Replacement, RAM: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • These are the screws located on the back cover of your laptop. They are JIS M2.5 x 7mm screws, which is the only type of screw you'll be dealing with in this guide. A Philips #0 iFixit screwdriver should fit these perfectly.
    • Unscrew all previously indicated screws like in the picture shown.
    • Keep the unscrewed screws somewhere secure so that you don't lose them. An inadequate number of screws can mean your laptop is unsecured at the base and may lead to damage.
  2. Dell Inspiron 7348 2-in-1 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your plastic prying tool and insert it into the gap between the back cover and the base of the laptop. This guide will use a plastic ruler for demonstration.
    • Pry open (gently) the back cover by pushing the tool upwards and if all screws are removed, the cover should pop off easily.
    • Do not use a metal tool as this can lead to electrostatic discharge damage.
  3. Dell Inspiron 7348 2-in-1 RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7348 2-in-1 RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 7348 2-in-1 RAM Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate this module with square black chips on the top.
    • The fingers rest where the metal prongs are on both sides of the module, which hold it in place.
    • Now that the hardware is exposed to the environment, make sure there is no danger of liquid spilling near the laptop. The lithium ion battery in the laptop can be dangerous when exposed to water.
    • Pinch and pry the metal prong outwards, and do the same to the other side.
  4. Dell Inspiron 7348 2-in-1 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 7348 2-in-1 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The module should stick up at a 45 degree angle, meaning it's loose.
    • Remove the module from the socket and get your replacement module ready.
  5. Dell Inspiron 7348 2-in-1 RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the replacement module in the same position that the old module rested.
    • Push downwards on the module. The metal prongs should audibly pop into place which is how you'll know the piece is secure.
    • Always think twice before exerting too much force on electronics if the piece does not secure itself immediately. Check if the module is placed correctly and then try again.
  6. Dell Inspiron 7348 2-in-1 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the back cover back onto the latop.
    • Press down on the edges and make sure the back cover is secure. Make sure it is fully sealed, as objects can enter the gap and damage the hardware.
    • Reinstall the screws into the same locations as before.
  7. Dell Inspiron 7348 2-in-1 RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Boot up your laptop, and voila! Your computer should be back up and running with renewed vigor in its RAM performance.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
JJ Chirat
crwdns2935283:006/10/25crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 1-2, Kapoor Summer 2025 crwdns2935289:0Austin Community College, Team 1-2, Kapoor Summer 2025crwdne2935289:0
AUSTINCC-KAPOOR-SU25S1G2
crwdns2942667:0crwdne2942667:0 38
