Dell Inspiron 6000 Keyboard Replacement
crwdns2942287:0crwdne2942287:0Removing and replacing the keyboard requires some disassembly and time.
Flip the laptop over, bottom-side up.
Push the switch next to the battery.
At the same time, lift the battery away from the laptop.
Place the laptop on flat surface.
Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
Carefully take a spudger and separate part of the cover at the red circle.
Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
Gently pull the blue tab up until it comes away from computer.
What kind of connector does the keyboard use I want to try and fit a newer motherboard in my old laptop
crwdns2935229:05crwdne2935229:0
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
