Dell Inspiron 16-7610 Touchpad Replacement
  1. Dell Inspiron 16-7610 Touchpad Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 16-7610 Touchpad Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the device over, so the backside is facing up.
    • Use a Phillips #00 screwdriver to remove four 4.00 mm screws.
    • Use the Phillips #00 screwdriver to unscrew or loosen two captive screws at the right and left corner near the hinges.
    • The last two screws should remain in the back case and can't be removed.
    • Three of the screws are dummy screws, only screwed into retainers. They are not holding anything in and can be left in place for simplicity.
  2. Dell Inspiron 16-7610 Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • -Use the opening tool between the seams of the top and bottom case to pry the back case off of the laptop.
    • Undo the clips gently as you pry the back of the device to avoid breaking them when removing the back case.
    • Remove the back case from the device.
  3. Dell Inspiron 16-7610 Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 16-7610 Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 16-7610 Touchpad Replacement, Battery: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 to remove the five screws securing the battery to the laptop.
    • Use the wide end of a spudger to push on the connector tab to slide it out of its socket.
    • If that doesn't work, pull the bundled cable away from the connector in the same direction as the wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Use both hands to remove the battery from the laptop.
  4. Dell Inspiron 16-7610 Touchpad Replacement, Touchpad: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 16-7610 Touchpad Replacement, Touchpad: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the touchpad up from outside of the palm rest assembly.
    • The ribbon cable ripped off of the touchpad on this device. In most situations, you will need to disconnect the cable from the motherboard prior to removing the touchpad.
After installing the new touchpad on the Dell Inspiron, retrace the previous steps to put the Dell Inspiron back together. Take your e-waste to an R2 or e-Stewards certified recycler.
Jerson Gomez
crwdns2935283:002/02/23crwdne2935283:0
892 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-3, Pee Spring 2023 crwdns2935289:0Gateway, Team 1-3, Pee Spring 2023crwdne2935289:0
GCC-PEE-S23S1G3
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 1,163
