The motherboard may be responsible for your computer not functioning as intended, it may be necessary to completely replace the motherboard.
Turn the laptop over to its back.
Slide the release latch while simultaneously pulling backwards on the battery.
Slide the battery out of the battery bay.
After removing the battery, remove the two screws (3mm Phillips #1) beneath it. These screws hold the Center Control Cover in place.
Flip the laptop over to the front and open the display as far as possible.
Pry the Center Control Cover from the laptop. On the right there is a small divot, it is advised that you start removing the panel from here.
Carefully lift the Center Control Cover away from the laptop.
Unscrew the four screws (3mm Phillips #1) that hold the base cover in place.
Carefully lift the base cover vertically away from the laptop.
Loosen the 5 screws (4mm, Phillips #1) that secure the CPU Heat Sink to the motherboard.
My fifth screw, (the one towards the bottom), won't unscrew. Anybody that can help?
Pull up on the Heat Sink unit to remove it.
Remove the two screws (5mm Phillips #1) at the top of the keyboard.
Slide the keyboard out and away from the laptop and lift it up to access the keyboard connector.
Lift the connector latch that secures the keyboard cable to the connector on the motherboard and remove the cable.
The connector latch is the black piece.
Good tip! As shown. flips up and toward user
Lift the keyboard up and away from the laptop.
Remove the 11 screws (5mm Phillips #1) from the back of the laptop as marked. One screw is in the middle, by the RAM.
If you’re using the ifixit pro tech toolkit and are having trouble getting the top screws, try using the flex connector. Took me a a few tries, but it worked for me.
Remove black and white wires from the WLAN that lead to the display by pulling straight up.
Unwind the wires from the routing guides.
Turn the laptop back over to its normal resting position and pull the black and white wires previously connected to the WLAN through the hole.
Remove the 4 smaller screws (5mm Phillips #1) and one screw on the top left (3mm Phillips #1) from the palm rest.
Disconnect the Bluetooth card cable, Wed cable, Camera1 cable, power cable, and touchpad cable from the respective Motherboard connectors as marked. For the Bluetooth cable and Camera1 cable, pull the plugs towards the screen. For the touchpad and power cable, lift the black tab and then pull them out. For the Wed cable, pull the blue tab up.
Unsecure the wires from the routing guides so they are loose.
To separate the palm rest from the rest of the computer, use a plastic opening tool to lift up the plastic. It is best to start at one point and work your way around.
Flip the laptop to its back side.
Remove the screw (5mm Phillips #1) that secures the Optical Disk Drive on the back of the laptop.
You really don’t need to have the “Flip the laptop to its back side” comment here, as you should have already done that to get the battery out due to having to slide the battery latch, which is on the bottom.
Push the Optical Disk Drive out using a spudger tool as shown and pull from the front cover of the Optical Disk Drive.
Remove the 3 screws (3mm Phillips #1) that secure the daughter board to the motherboard.
Lift the daughter board away from the laptop.
So I’m dumb. Remember to take out the slot that pulls from the side!
Remove the two screws (3mm, Phillips #1) on the left and the two screws (5mm, Phillips #1) on the right that secure the Motherboard to the laptop.
Disconnect the Thermal Fan cable, Speaker cable, and USB Board cable from their connectors.
To remove the Motherboard, pull away and up from the base of the laptop.
Great job. Couldn’t have done it nearly as fast without making mistakes. Thank you.
crwdns2935229:022crwdne2935229:0
Thank you so much for the guide extremely helpful
im trying to find out for sure with out any question at all that this motherboard is infact the right one i am paying for… i want my old laptop to work like brand new as it did about four weeks ago.. granted it had windows 7 at the time of mr, laxton i hope that you can offer me a complete windows 10 updates.. seems like every where we try and move too..when we do move ..it dont take long to set it up//as long as they keep
