Dell Inspiron 15-5558 Screen Replacement
  1. Dell Inspiron 15-5558 Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure you turn off the device before starting.
    • Flip the device over and so the white bar code is on the right.
  2. Dell Inspiron 15-5558 Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery latch all the way to the left until you hear the click and see the battery prop up.
    It is no big deal but try to erase the service tag.
    Somecan even summon the Dell support to you by it and make a fuss.
    Why am I saying this? this is internet and there are various people. Try to be safe before rant.
    Kind-hearted, spirited Man - crwdns2934203:0crwdne2934203:0
  3. Dell Inspiron 15-5558 Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-5558 Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the battery up and remove it.
  4. Dell Inspiron 15-5558 Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 15-5558 Screen Replacement, Screen: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open device so it is at least opened at a 90 degree angle.
    • Wedge a spudger between the screen and the plastic frame.
    • Push in the spudger and push down to pop the frame from the pins.
    • Repeat around the whole frame.
    Will need a heat gun. The Bezel is glued with double sided tape.
    Nicholas Cain - crwdns2934203:0crwdne2934203:0
  5. Dell Inspiron 15-5558 Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5558 Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5558 Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once all the pins are off, remove the frame by pulling it away from the screen.
    • Using a Phillips #0 screwdriver, unscrew the four 3mm screws holding the screen in place.
    • Push the spudger behind the screen and push down to remove the screen.
  6. Dell Inspiron 15-5558 Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5558 Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 15-5558 Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the tape connecting the screen up with your fingers and pull the securing bar up with it.
    • Disconnect the securing bar to remove the screen.
Adam Lourenco
crwdns2935283:010/19/17crwdne2935283:0
793 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G4, Bailey Fall 2017 crwdns2935289:0UMass Dartmouth, Team S3-G4, Bailey Fall 2017crwdne2935289:0
UMASSD-BAILEY-F17S3G4
Where can I buy the screen from?
wardak_90 - crwdns2934203:0crwdne2934203:0
How many pins is the screen connector? 30? 40?
Adrian Lewis - crwdns2934203:0crwdne2934203:0
Very useful guide. Works with Dell Inspiron 15 5559. Screen replacement is a lot easier than replacing the whole screen assembly.
James Diamond - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 4,862
