Dell Inspiron 13-7347 Display Assembly Replacement
  1. Dell Inspiron 13-7347 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over, so that the back is facing up.
    • Using a Phillips screwdriver, remove the 10 2.5mm x 8mm screws
    • Use the suction cup to lift off the back case.
  2. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 2mm x 3mm screws that secure the battery to the device.
  3. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the cable that connects the USB / SD Reader IO Board to the motherboard.
  4. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery steadily from the device.
    • Tilt the battery upward while removing.
  5. Dell Inspiron 13-7347 Display Assembly Replacement, Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement, Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You should be able to identify the fan.
    • This is the 2mm x 2mm JIS #00 screw.
    • This is the 2mm x 3mm JIS #00 screw.
  6. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 2mm x 2mm JIS #00 screw.
    • Remove the 2mm x 3mm JIS #00 screw.
  7. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the cable that connects the fan and the motherboard.
    • The cable is extremely fragile.
  8. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the cord that connects the fan and the motherboard.
  9. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan.
  10. Dell Inspiron 13-7347 Display Assembly Replacement, Hard Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement, Hard Drive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #0 screwdriver, loosen and remove the two 3.0 mm hard drive screws.
    • Lift the hard drive up and out of the device.
  11. Dell Inspiron 13-7347 Display Assembly Replacement, Display Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement, Display Assembly: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement, Display Assembly: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screwdriver, loosen the three 3.0 mm heat sink screws.
    • Remove the Heat Sink.
    • When reinstalling the heat sink, be sure to clean both contact surfaces with isopropyl alcohol and reapply thermal paste.
  12. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the two 5.0 mm screws on the metal bracket.
    • Remove the metal bracket.
  13. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen and reposition the display cable.
    • The display cable will not be removed. Do not attempt to remove the display cable.
  14. Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Inspiron 13-7347 Display Assembly Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the 5.0mm screw on the left display hinge bracket.
    • Using a Phillips #0 screwdriver, remove the two 5.0mm screws on the right display hinge bracket.
    • Lift and remove the display assembly.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Kyle Smith
crwdns2935283:010/02/19crwdne2935283:0
331 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S2-G8, Eggleston Fall 2019 crwdns2935289:0The Citadel Military College of South Carolina, Team S2-G8, Eggleston Fall 2019crwdne2935289:0
CMCSC-EGGLESTON-F19S2G8
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 742
