This is a simple step-by-step guide on how to remove and replace a battery for a Dell Inspiron 13-5368.
Remove the nine 6mm Phillips #0 screws that secure the back cover of the laptop.
Use a spudger / pry tool to pry up and remove the back cover.
Remove the four 3mm Phillips #0 screws at the corners of the battery that secure it to the laptop.
Pull the battery cable's black tab towards the battery to disconnect it from the motherboard.
Lift the battery straight up out of the housing.
For optimal performance, after completing this guide, calibrate your newly installed battery.
crwdns2935229:014crwdne2935229:0
Awesome, very user friendly instructions. Was not looking forward to taking to computer repair store to replace internal battery. Thank you so much for these instructions.
The new battery replacement does not come with a cable to attach to the motherboard. How can I use the cable from the old battery?
I have this same question^. Can I reuse the cable from the old battery?
