This guide will show you how to replace the battery of the Dell Inspiron 11-3168. Before starting, make sure both the laptop AC adapter and battery are disconnected prior to replacing any part or component.
Using a Phillips #00 screwdriver, remove all nine 7.5mm screws from the bottom case of the laptop.
Remove the bottom case of the laptop by gently prying along the seam with a plastic opening tool.
Remove the one 7.5mm screw that is holding the battery in place.
Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Well done with the instructions. AND I just noticed you attend - attended a school in El Dorado? I grew up in Pine Bluff. Your presentation was a big help to me.
Your are welcome Phillip. I am glad you found that repair guide to be helpful.
