Dell G15-5511 Gaming Right SSD (Slot 2) Replacement
  1. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unfasten the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unfasten the back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws that secure the cover.
    • Use a Phillips #1 screwdriver to loosen the four captive screws.
  2. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unclip the front corners: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unclip the front corners: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  6. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The right SSD slot has two locations install the standoff bracket—one for the short M.2 2230 SSD, and one for the longer M.2 2280 SSD.
    • Use the flat end of a spudger to press the the bracket into the slot. The wings of the standoff will clip underneath the tabs of the slot.
    • Slide in the standoff edge of the bracket first.
  7. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Insert the SSD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Insert the SSD: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip your 80 mm-long (M.2 2280) SSD by the corners near the screw indent.
    • Slide the SSD into the socket.
  8. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Fasten the SSD: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Fasten the SSD: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your Phillips #0 screwdriver to fasten the 4.2 mm-long screw to the SSD standoff.
To reassemble your Dell G15, follow these instructions in reverse order.
For general information on how to install a SSD, refer to this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
86,055 crwdns2915208:0crwdne2915208:0
crwdns2935297:0455crwdne2935297:0
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 5,046
