Dell G15-5511 Gaming Battery Replacement
  1. Dell G15-5511 Gaming Battery Replacement, Unfasten the back cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement, Unfasten the back cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws that secure the cover.
    • Use a Phillips #1 screwdriver to loosen the four captive screws.
  2. Dell G15-5511 Gaming Battery Replacement, Unclip the front corners: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement, Unclip the front corners: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. Dell G15-5511 Gaming Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5511 Gaming Battery Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement, Remove the back cover: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5511 Gaming Battery Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement, Disconnect the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  6. Dell G15-5511 Gaming Battery Replacement, Unfasten the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement, Unfasten the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the four 4.1 mm-long screws securing the battery.
  7. Dell G15-5511 Gaming Battery Replacement, Remove the battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement, Remove the battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell G15-5511 Gaming Battery Replacement, Remove the battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the battery towards the top of the laptop to separate it from its plastic shell.
    • Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
202,937 crwdns2915208:0crwdne2915208:0
crwdns2935297:0956crwdne2935297:0
Staff
crwdns2935297:023,425crwdne2935297:0
crwdns2936753:030crwdne2936753:0 143
crwdns2942667:0crwdne2942667:0 4,082
