Dell Chromebook 11 CB1C13 Battery Replacement
  1. Dell Chromebook 11 CB1C13 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dell Chromebook 11 CB1C13 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure that device is fully powered down before attempting to open the back case.
    • Remove all seven 8mm Philips #0 screws from the back case with a Philips #0 screwdriver.
    • Once all seven screws are removed, you can pry the case off using your fingers or a plastic opening tool.
  2. Dell Chromebook 11 CB1C13 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 11 CB1C13 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to unscrew the four 8 mm screws that secure the battery.
  3. Dell Chromebook 11 CB1C13 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dell Chromebook 11 CB1C13 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger to push the bundled cable connector free in the same direction as the individual wires are running.
    • You can use your fingers to help pull the cable free. Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Proceed to gently remove the battery from the back panel.
To replace your Dell Chromebook 11 battery, follow these instructions in order.
Jerry Geffrard
crwdns2935283:003/25/15crwdne2935283:0
334 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G6, Bailey Fall 2017 crwdns2935289:0UMass Dartmouth, Team S3-G6, Bailey Fall 2017crwdne2935289:0
UMASSD-BAILEY-F17S3G6
crwdns2942667:0crwdne2942667:0 1,549
