Debadging a Car
  1. Debadging a Car, Debadging a Car: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Debadging a Car, Debadging a Car: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Debadging a Car, Debadging a Car: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Begin by thoroughly wetting the badge and surrounding area with soapy water.
    • Once the badge is fully wetted, wedge a strand of floss or fishing line between the car panel and the wedge.
    • Do not use metal fishing line or metal wires, as these will damage the paint.
    • Draw the floss back and forth in a sawing motion and simultaneously pull it along the badge until it detaches from the panel.
  2. Debadging a Car: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Debadging a Car: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use soapy water and the rough side of a sponge to remove the leftover adhesive. Other products such as Goo Gone or Goof Off are also excellent adhesive removers.
    • Be sure to monitor your scrubbing carefully. If you scrub too hard in one area, you will damage the paint.
    Fishing line works the best! Don't be discouraged if you see a shadow from the removed badge; it will fade and disappear with time. You have to figure the badge has been on the vehicle since it was manufacturered. Debadging your vehicle, gives it a clean, professional upper class look to it and its always funny to watch service techs try and figure out what make/model your vehicle is. No one has gotten it right yet. Corolla CE
    kreigerp - crwdns2934203:0crwdne2934203:0
There you have it. A fresh clean tailgate without any badge.
crwdns2935229:022crwdne2935229:0
This thanks for this post, many of people have craze to use custom badge. This is good think you can get choice to use any of custom badge to stick on car with the Instant Adhesives.
Bryan - crwdns2934203:0crwdne2934203:0
Floss is a good idea. I would suggest using a hair dryer to first heat the area to soften the adhesive. When done you can use duct tape to "lift" small patches of remaining adhesive by pressing duct tape firmly over small sections of adhesive and then lifting straight up.
Mike - crwdns2934203:0crwdne2934203:0
I find ifixit's conclusion to be rather comical; To reassemble your device, follow these instructions in reverse order.
grumblerts - crwdns2934203:0crwdne2934203:0
Rather than using an abrasive washing up sponge, try using a soft cloth with WD40. It will dissolve the remove the adhesive without risking damaging the paintwork.
Gordon Grace - crwdns2934203:0crwdne2934203:0
Per esperienza, non è il caso di usare il lato ruvido di una spugna da cucina in quanto ti lascerà bruttissimi aloni e la vernice opacizzerà dove si ha passato la spugna. Piuttosto consiglio di usare prodotti “leva colla” o “leva etichette” e la colla rimasta sulla vernice sparirà.
Ottima idea quella del filo interdentale, sicuramente da provare.
Grazie mille
Leo - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 108
crwdns2942667:0crwdne2942667:0 21,743
