DR.J Professional HI-04 Speaker Replacement
  1. DR.J Professional HI-04 Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement, Speaker: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Speaker Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Squeeze the tab against the connector, and pull the connector straight from the socket to disconnect the speaker cable from the port.
    • The cable should come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
    • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
  7. DR.J Professional HI-04 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the black cover.
  8. DR.J Professional HI-04 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the back panel with the speaker up from the bottom case of the project.
  9. DR.J Professional HI-04 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Speaker Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 10.0 mm screws that secure the speaker.
Baron Dutra
crwdns2935283:011/01/23crwdne2935283:0
825 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Petersen Fall 2023 crwdns2935289:0UMass Dartmouth, Team 1-5, Petersen Fall 2023crwdne2935289:0
UMASSD-PETERSEN-F23S1G5
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 162
