Use this tutorial to replace a faulty speaker in your HI-04 mini projector. You might notice distorted sound, or static, or the device won't produce sound at all.
A speaker is a device inside of the projector that produces the sound you hear from the device. You might get a faulty speaker due to damage over time or if the device is physically damaged.
Before using this guide, be sure to review the troubleshooting guide. Sometimes issues with the noise can be fixed by restarting the device, which wouldn't require replacing the speaker.
Flip the projector so that the bottom is facing up.
Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
Remove two 20.0 mm screws with a Phillips #0 screwdriver.
Flip the projector so it is upright.
Remove the top case of the projector.
Remove the three pieces of tape securing cables.
Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
Squeeze the tab against the connector, and pull the connector straight from the socket to disconnect the speaker cable from the port.
Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
Slide the back panel with the speaker up from the bottom case of the project.
Use a Phillips #0 screwdriver to remove the two 10.0 mm screws that secure the speaker.
