DR.J Professional HI-04 Motherboard Replacement
  1. DR.J Professional HI-04 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the projector so that the bottom is facing up.
    • Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
    • The screws are set deep in the holes. Be careful not to drop the screws.
    • Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The top case should come off fairly easily but be gentle while removing it.
    • Don't yank the top case off as there are cables attached to the motherboard and the top case.
  3. DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the tab against the connector, and pull the connector straight out from the socket.
    • The cable will come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard from the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector.
    • Pull the cable from the connector.
  7. DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DR.J Professional HI-04 Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Set down the motherboard safely.
Baron Dutra
crwdns2935283:011/01/23crwdne2935283:0
825 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Petersen Fall 2023 crwdns2935289:0UMass Dartmouth, Team 1-5, Petersen Fall 2023crwdne2935289:0
UMASSD-PETERSEN-F23S1G5
Baron, thanks for the guide. My projector took a tumble and landed right on the back where the input/power plug is. I plugged it back in and the red light turns on, but that's all. I don't hear any loose parts and it definitely wasn't overheated. Any ideas on what it could be? Trying to get the right screwdriver to open it up later this week.
Socev - crwdns2934203:0crwdne2934203:0
Baron, where would I find a replacement mother board?
Thanks
Stew
Stewart Debbie Greer - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 216
