DOSS SoundBox Battery Replacement
crwdns2944105:0crwdne2944105:0
Use a JIS #00 screwdriver to remove the four 3/32" screws that attach the base-plate to the speaker enclosure.
Use a JIS #1 screwdriver to remove the six 3/32" screws marked with a red circle.
Remove the two 1/16" screws marked with orange circles using a JIS #000 screwdriver.
Remove the six 3/32" screws marked with red circles using a JIS #00 screwdriver.
Remove the larger 3/32" screw indicated by an orange circle using a JIS #1 screwdriver.
Once the screws are removed, gently lift the top (where the touch controls are) off of the speaker.
De-solder the connections from the battery to the circuit board.
Thank you. It's 2023 and I needed to get my speaker up and running again.
What could be the cause that the box works perfectly on low volume, but as soon as I raise the volume the box shuts down?
Thanks so much for your work here. :)
Hi. Thanks for the guide! Can you please let me know how to remove the existing batt, I don’t know if it’s glued or sthing but I can’t take it out, I m stuck there. Tks !!
Did you manage to get it removed? I don’t know any more details than what this guide offered, but if it is glued in, isopropyl alcohol or some low heat are usually quite helpful. Make sure the battery is drained beforehand, of course, though I doubt it’ll be an issue since you’re trying to replace the battery, most likely because it’s not holding a charge anymore. If you use isopropyl, you can get fairly liberal with it without having to worry about damaging anything so long as you don’t get any on the speakers because the glue used to hold them together can desolve causing separation which would ruin the sound and would need repair.
Link for Battery Replacement is broken.
Wait, wait, wait!… Were the previous 4 steps even necessary or are you suggesting we take the same trial and error exploratory approach to this that the author seems to have instead of just going for what has already been determined (through said trial and error exploration) as the proper ingress point for a motherboard replacement…the bottom plate?
Thousand Sunny - crwdns2934203:0crwdne2934203:0
