DJI Phantom 4 Advanced Remote Controller Motherboard Replacement
  1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
cade knott
crwdns2935283:010/02/18crwdne2935283:0
496 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team S1-G4, Johnson Fall 2018 crwdns2935289:0Linn Benton Community College, Team S1-G4, Johnson Fall 2018crwdne2935289:0
LBCC-JOHNSON-F18S1G4
Do you know here can i buy a main board for phantom 4 advanced remote controller?
carl_darklife - crwdns2934203:0crwdne2934203:0
I would like to know too, can’t find one anywhere
Luke James -
crwdns2942667:0crwdne2942667:0 2,275
