This guide will show you how to replace each motor. The screws that hold each motor in place will have to be removed and the wires that attach to each motor will have to be desoldered.
With the battery facing you, locate the two tabs on the top and bottom of the battery as shown.
Press the two tabs with your finger and thumb, and gently slide the battery towards you, out of the quadcopter frame.
With your other hand, be sure to hold the quadcopter steady to ensure that it stays still.
Turn the Phantom 3 Advanced upside down.
Remove the four 7mm long 2mm screws with a T-6 screwdriver.
Remove the eight 5mm long 2.5mm screws using the T-8 screwdriver.
Remove the four 10mm long deep 3mm screws using the T-8 screwdriver.
Carefully flip the phantom back over with the motors facing up.
Peel back the silver stickers from the seam in the cover.
Using a plastic spudger, slowly separate the two halves of the plastic shell.
Slowly remove the upper half of the plastic case about halfway. There is a ribbon cable that's connects the cover and the control board.
Follow the ribbon cable to the control board and locate the connector that connects the cable to the control board.
Press the tab on the side of the connector and pull up on the cable.
Continue to remove the shell the rest of the way.
“Press the tab on the side of the connector and pull up on the cable.”
The 2015 W323A model I am working on has no tab on the side of the connector. Connector released quite easily when I applied upward pressure away from the board, pulling on the all wires together. A little wiggle side to side helped. Be patient. It’s a small connector.
Turn the drone upside down with the motors facing the table.
Unscrew the four 5.5mm long 3mm screws directly under the motor using a 2.0mm hex bit screwdriver.
Remove the glue that covers the three wires that connect the motor to the flight controller. Use a plastic opening tool or a metal tool if needed.
Repeat for each arm.
Trace the black, yellow, and red wires from the motor to the flight controlle .
Desolder the three wires where they connect to the flight controller. Check out this desoldering guide to learn how to desolder: Desoldering Guide.
Take out the motor and repeat for the other motors if needed.
what about if the motor wire is short?
and what kind of glue i’ve to put on, when i’ll replace motors ?
tank you for your work
Rather than desoldering the leads from the board, I spliced and soldered them, and used heat shrink tubing to insulate. I figured it might add a few grams to the flying weight, but it was an easier repair than working directly on the board.
crwdns2935229:08crwdne2935229:0
Great teardown, clear instructions, thank you!
