DBPOWER T20 Fan Replacement
crwdns2942287:0crwdne2942287:0Taking out the fan is quick and easy. When removing the fan it is okay to use some force as it's not delicate.
Flip the device and lay flat.
Remove the four (9 mm) screws with a PH2 screwdriver.
Remove the two (7 mm) located with a PH2 screwdriver.
Flip the device over and pry the top off with a plastic opening tool.
Remove the ribbon cable connecting the motherboard to the button control board by gently pulling it from its connector.
which end of cable?
looks hard and tightly connected. put an arrow
Remove four (6 mm) screws connecting the motherboard using a J0 screwdriver.
one of the screws have been stripped, I’ve tried the rubber band and the glue trick, it didn’t work. What do I do to remove it? please respond
Remove the two cables connected to the motherboard: black power cable and the red/black fan cable.
Lift the black latch on the ZIF connector and remove the ribbon cable that attaches the digitizer to the motherboard.
very well explained, let's also tell the other one how it goes
Raise motherboard by lifting sideways and then up to avoid the ports.
Remove wires attaching the piezoelectric speakers to the motherboard.
Remove the five screws securing the black plastic cover with a J0 screwdriver.
Lift up and out to remove.
Pull the fan up and out of the housing.
Any idea of the specifications of the fan? 12v, 24v? I want to change it for another more quiet… but not sure about its voltage. It is 50x50x20mm right? Thanks!
Agustín Castiñeira Fernández - crwdns2934203:0crwdne2934203:0
Hola! También querria sustituirlo por otro más silencioso. ¿Alguna idea de sus especificaciones?
