D-Link DIR-890L Power Adapter Port Replacement
  1. D-Link DIR-890L Power Adapter Port Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement, Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the four rubber rectangular feet with your fingers.
    • The feet may be hard to remove. Apply additional force if necessary.
  2. D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
  3. D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Wedge the opening tool between the red top panel and the gray bottom panel.
    • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
  4. D-Link DIR-890L Power Adapter Port Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  5. D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Heavy-Duty Spudger
  6. D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  7. D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  8. D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  9. D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  10. D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the power adapter port at the top left of the motherboard.
    • Flip the motherboard over.
    • Locate the 3 solder joints that connect the power adapter port to the motherboard.
  11. D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 D-Link DIR-890L Power Adapter Port Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Desoldering Pump
    $3.99
    • Using a soldering iron and desoldering pump, desolder the power adapter port from the board.
    • For more information, see this guide on desoldering
Rachel Shaw
crwdns2935283:010/06/16crwdne2935283:0
553 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-7, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 10-7, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S10G7
What are the specifications of the power port if we would like to replace it?
Chad Altobelli - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 680
