CyberHome CH-DVD 300 Power Supply Replacement
  1. CyberHome CH-DVD 300 Power Supply Replacement, Top Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CyberHome CH-DVD 300 Power Supply Replacement, Top Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the DVD player off. Unplugging the DVD player while it is on may result in damage to the DVD player or an inserted CD.
    • Unplug the DVD player from the wall socket.
    • Locate the 15mm Phillips screws on the left side (1 screw), right side (1 screw), and back (4 screws) of the DVD Player. Use the appropriate Phillips head screwdriver to remove the six screws.
  2. CyberHome CH-DVD 300 Power Supply Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 CyberHome CH-DVD 300 Power Supply Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the top panel of the DVD Player by:
    • Sliding the top panel backwards.
    • Gently lifting the back of the top panel up.
  3. CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 CyberHome CH-DVD 300 Power Supply Replacement, Power Supply: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the device to locate the power supply board on the far right corner. Use needle nose pliers to pull the white connector from the power supply board.
    • The power supply board is connected directly to the power cord. This is not the same thing as the mother board.
    Where can i get the new board?
    semyonaxelrod - crwdns2934203:0crwdne2934203:0
    Where can I get a new power supply board?
Chris Menezes
crwdns2935283:004/07/14crwdne2935283:0
654 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-5, Forte Spring 2014 crwdns2935289:0Cal Poly, Team 6-5, Forte Spring 2014crwdne2935289:0
CPSU-FORTE-S14S6G5
crwdns2947412:08crwdne2947412:0
Mine had a bad 2200uf 10v capacitor… I replaced it and the player works fine.
Robert Brackett - crwdns2934203:0crwdne2934203:0
What and where is that located please?
Kealani Rowe -
So what capacitor have u replaced ?
semyonaxelrod -
I need another power supply board. Mine has 4 blown Capacitors and do not know if any resisters or diodes or small capacitors are bad because I have now testing tools to check them. Just what I see with eyes. Am a retired electronics professional (79) and know what I am doing. Please let me know if I can get a power supply board and the cost. Thank You .
Glennie Waters - crwdns2934203:0crwdne2934203:0
So I guess no response?
semyonaxelrod -
DVD is plugged in, yellow light glowing flickering, pushed button to turn on, see green light and let go, back to yellow light again!
Help
Mary Ann - crwdns2934203:0crwdne2934203:0
I want to use this board as a project power supply. Any idea in the spec for the 12v and 5v as regard to watts/amps?
Colin Manuel - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,110
