This guide is a prerequisite for the guide: [crwdns2936915:0crwdne2936915:0]. It is not intended to be used as a standalone guide as it is used when integrating steps where I need standardized instructions.
Sony: Sony a5X000 (SW driven) Sony Alpha (Advanced, a6X00 and up) Sony NEX (FOR NEX-5N; NOT CHECKED)
Switch the camera into a Manual mode (P/A/S/M; doesn't matter). You MUST be in a "manual" mode to use custom WB settings.
Open the menu and select the following: Camera settings>White Balance.
NOTE: The location of the white balance setting varies from camera to camera. Keep this in mind if you do not see the setting as shown in my demo a6000. (Ex: a6000 is Line 4, a6100 is under Line 9 and a6300 is under Line 5.
Select the White Balance option, and scroll down until you see Custom Setup. Take a picture of your lighting setup and press the Enter button to save it to the camera.
Take a picture of your workspace without any objects; it must be empty and have no outside elements to affect the WB. Full auto can be used.
Put the camera in one of the 4 manual modes (P/A/S/M). Select the red menu (Menu 2), then select Custom white balance.
Select the white reference photo. Press SET on the camera. Once this is done, the camera will save the custom white balance.
