This guide will teach you how to replace the motor inside your Cuisinart Smart Stick. If power is not being supplied to the Smart Stick, the motor could be unresponsive.
Located on the back of the motor body are three screw covers. To remove the three grey screw covers, use a Flat Head Screwdriver (1.0mm or 1.5mm).
After prying these off, the screws will be exposed.
Remove three 13.3 mm Phillips PH#2 screws.
Pry open Cuisinart using a plastic opening tool.
Make sure to pry open near the clips of the smart stick for easy opening.
Unscrew the 4 screws on inside.
Remove 2 13.3mm Phillips PH#2 screws.
Remove 2 17.5 mm Phillips PH#2 screws.
Refer to these steps on Soldering to replace the motor in the smart stick.
crwdns2947412:07crwdne2947412:0
where can I find the coupling from the motor to the shaft?
Thanks for this tutorial Jordan! I have the same question than Alejandro Serra though, I was wondering if someone know where we can find the plastic coupling between the motor shaft and the kitchen tool. Mine is striped and I can’t find this specific part. This is a shame since the motor is in perfect shape so just a little plastic part is ruining the whole device. If anyone has see this part or if you have a way to fix a stripped one, please let me know!
Hello, did u ever end up finding this same piece of plastic you were looking for? Turns out mine is stripped too and i need one
Does anyone know where to find small replacement parts for this? I'm specifically looking for the white (I think nylon) cylindrical piece which is held by friction to the motor shaft, and which has teeth on the inside to engage with the blade shaft.
Still nothing?
Where did you find the motor? I'm searching for one with no luck.
I didn't find the plastic coupling either, but someone made a 3d printing models. It's for the CSB-76BC model but it seems to be standard for Cuisinart smart sticks. I printed it and it works for mine which is a CSB-85C (use a strong plastic like nylon for the printing).
