Cuisinart DFP-14BCN Switch Replacement
  1. Cuisinart DFP-14BCN Switch Replacement, Bowl: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement, Bowl: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement, Bowl: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
    The little white thing that pushes down broke
    Mr. potato - crwdns2934203:0crwdne2934203:0
  3. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
    It seems so simple and obvious. Thanks for your help!!!
    Carrie Shirley - crwdns2934203:0crwdne2934203:0
  6. Cuisinart DFP-14BCN Switch Replacement, Back Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement, Back Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Switch Replacement, Buttons: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement, Buttons: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement, Buttons: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
  14. Cuisinart DFP-14BCN Switch Replacement, Switch: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart DFP-14BCN Switch Replacement, Switch: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Desolder the white, black and red connections from the switch by using a soldering iron.
    • Refer to the soldering guide for extra help.
    • For reassembly, the new switch's connections will have to be soldered on.
Sonya Dick
crwdns2935283:010/05/16crwdne2935283:0
352 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-3, Livingston Fall 2016 crwdns2935289:0Cal Poly, Team 10-3, Livingston Fall 2016crwdne2935289:0
CPSU-LIVINGSTON-F16S10G3
You had me until the desoldering, maybe I’m just a wimp! Thanks anyway … good description!
dmdudek - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,685
