crwdns2935311:0crwdnd2935311:0crwdne2935311:0 crwdns2935313:0Toastercrwdnd2935313:0crwdnd2935313:0crwdne2935313:0
  1. Cuisinart 4-Slice Tandem Toaster Teardown, Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This Cuisinart Toaster's technical highlights include:
    • Tandem, 2-slot toaster
    • 1½" wide toasting slots
    • Function control dial
    • Bagel, Defrost and Reheat selections
    • Blue LED shade control with large, easy-to-read numbers
    • 2 or 4 slice button; cancel button
  2. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the toaster prior to teardown.
    • On the bottom of the toaster, unscrew the 4 Torx screws (using a screw driver)
  3. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the press handle down and away from the toaster to disconnect the body.
    • Lift up the body of the toaster.
  4. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the pin header cable to disconnect the body of the toaster from the main assembly unit.
  5. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 5 Torx screws to detach the heating unit from the bottom of the toaster unit.
  6. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, carefully pry open the metal casing underneath the toaster.
  7. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws to detach controls from the plastic shell of the toaster.
  8. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Interior of the user control interface
  9. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the soldered wire that is hooked to each part of the end plate assembly.
  10. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Heating Unit
  11. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This is the Circuit Board used for controlling each subsystem of the toaster.
    • The integrated circuit marked 4541 contains an oscillator which oscillates at some hundreds or thousands of oscillations per second, the speed being determined by the browning setting. It also contains a binary counter which can count up to 65,536.
    • The integrated circuit marked 4066 contains several logic gates which select the count value required for normal, defrost or reheat.
    • During the count, the logic gates supply a small current to the transistor, causing it to energise the electromagnet. At the end of the selected count, the logic gates switch this current off and the transistor de-energises the electromagnet.
    • While energised, the electromagnet holds the lever down. When the current is switched off the lever is released and the spring pops the toast up.
    • Toasters of this age frequently use these "4000-series" integrated circuits as they can run off a wide range of supply voltages. Newer toasters use a microcontroller (essentially a simple micro computer) as this is more flexible in its functions and can also easily drive LEDs to show you what the toaster is doing.
  12. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Main Assembly Unit
  13. Cuisinart 4-Slice Tandem Toaster Teardown: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Main Element Assembly
    • Crumb Tray with Power Cord
    • Circuitry with Heating Component
    • User Control Interface with Buttons
    • Press Handle Spring
Lucas
crwdns2935283:003/02/14crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
Have this broken device and would be glad to us this demonstration to fix it!
Robert Scherer - crwdns2934203:0crwdne2934203:0
Thanks for this great post-up. Saved me a lot of time not having to figure out the disassembly. Hope my comments will further help others trying to do the same.
Cheers!
Keith
K Lynch - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,025
