Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement
  1. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power cord from the wall outlet first, disconnecting power from the device.
  2. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Orient the device with with the LED facing away from the user allowing access to the input jack of the power cord.
  3. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grasp the power cord input connector firmly with forefinger and thumb.
    • Without tugging, apply pulling force until the connector is free from device
    I want just the electric cord only that’s work on Crock-Pot 6 qt thank you
    Le White - crwdns2934203:0crwdne2934203:0
  4. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Lid: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Lid: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Lid: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the crock pot where the lid locked and unlocked icons are visible.
    • Grasp the handle firmly and turn the lid clockwise until the arrow and the lid unlocked icon are facing each other.
    • Remove the lid.
    Bobber Valve Gasket
    SKU: SAP_196077000000
    link no longer works because 10qt piece discontinued. They are shipping me valve for 8qt lid to see if it works. I have attached part number for 8 qt bobber valve gasket.
    Thanks
    Bo Peep - crwdns2934203:0crwdne2934203:0
  5. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement, Sealing Ring: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the lid over, exposing the underside and sealing ring.
  6. Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Crock-Pot Express Crock Multi-Cooker Sealing Ring Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, work your way in between the metal and sealing ring.
    • Continue to rotate and pry with the plastic opening tool until the sealing ring separates from the top.
    I store my Crockpot Express Multicooker in the locked position. For some reason, it won’t lock. The sealing ring is properly installed. Can you help me - any ideas. Thanks.
    Susan Reinhardt - crwdns2934203:0crwdne2934203:0
    I don't have a plastic opening tool
    diananoe1451 - crwdns2934203:0crwdne2934203:0
    I put a new seal in, now it won't seal!
    modesty.labbe - crwdns2934203:0crwdne2934203:0
    I have the same questions. Do you ever respond to comments? If not, this is a total waste.
    Rach Replogle - crwdns2934203:0crwdne2934203:0
    I found a replacement on Amazon https://a.co/d/5sxu7bP for my 10 qt crock pot express. To make sure I had the right size gasket/ring, I first place the silicone ring over the edge of my pot where the lid goes. The middle part of the ring should sit perfectly on top of the pot. Mine did. YAY!
    It was a very, very tight fit in the lid and since i did not have a plastic tool to help push it under the metal ring that holds it in place, I used the base of a thin table knife to put the presser on the ring as I pressed down on it at the same time. In the same manner the gentleman on the video was doing it to get it in. The gasket must go in so that the center lip sits on the lids inside edge or your lid will not close.
    Tough job but it can be done.:)
    pichin3 - crwdns2934203:0crwdne2934203:0
William Kelly
crwdns2935283:009/24/18crwdne2935283:0
817 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G9, Eggleston Fall 2018 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G9, Eggleston Fall 2018crwdne2935289:0
CMCSC-EGGLESTON-F18S3G9
crwdns2947412:08crwdne2947412:0
Thank you for giving me the answer to how to be sure I assemble the seal correctly in the Crock Pot Express after we clean the cooker after I unboxed it. A video should be included with the Crock pot Express , it wwould help a lot. There were no pictures of the underside of the lid. The placement of gasket is very crucial to safety. I used a pressure scanner years ago. Iam impressed with the E6 flashing on the control panel. I do like the cooker overall!
gnag321 - crwdns2934203:0crwdne2934203:0
Thank you very much for the advice. Now I can make sure I am placing the gasket in the cooker correctly. I used a pressure scanner/ cooker 30years ago! I like the e6 warning which was on the control panel to let me know that the pressure was not building up. I was able to let the steam off.
This gasket / seal seems very loose and ill fitting. Is this normal?
mark.e.betty - crwdns2934203:0crwdne2934203:0
I agree it falls off mine on it’s own
gestep -
Where do I find the question & response to gnag321 ?
I have same question as mark.e.betty. I seem to have the seal in in the only way it will fit. Please advise as I love this machine & want to a lot more cooking. Tks
Can't find the silicone seal for my mod. #sccppc804-v1 Crock Pot Pressure Cooker machine?
Mavis Sandberg - crwdns2934203:0crwdne2934203:0
how many sealing rings does a crockpot express have
lindakjonas - crwdns2934203:0crwdne2934203:0
Hi, having trouble with sealing ring. Keeps falling off. Mine is not silicone but rubber. Does this make a difference?
Lynette squires - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 9,682
